取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
IE-4010工业交换机
Are you ok
! transceiver type all internal allocation policy ascending ! ! ! ! ! ! interface GigabitEthernet1/1 description PLC-1517F switchport mode trunk switchport voice dot1p ! interface GigabitEthernet1/2 switchport mode trunk ! interface GigabitEthernet1/3 ! interface GigabitEthernet1/4 switchport mode trunk ! interface GigabitEthernet1/5 description MCC3 switchport mode trunk ! interface GigabitEthernet1/6 description MCC4 switchport mode trunk ! interface GigabitEthernet1/7 description MCC5 switchport mode trunk ! interface GigabitEthernet1/8 ! interface GigabitEthernet1/9 switchport access 20 switchport mode trunk ! interface GigabitEthernet1/10 switchport mode access ! interface GigabitEthernet1/11 switchport mode trunk ! interface GigabitEthernet1/12 no switchport address 192.168.2.1 255.255.255.0 ! interface GigabitEthernet1/13 ! interface GigabitEthernet1/14 ! interface GigabitEthernet1/15 ! interface GigabitEthernet1/16 ! interface GigabitEthernet1/17 description MCC1 switchport mode trunk ! interface GigabitEthernet1/18 description MCC2 switchport mode trunk ! interface GigabitEthernet1/19 description MCC6 switchport mode trunk ! interface GigabitEthernet1/20 ! interface GigabitEthernet1/21 ! interface GigabitEthernet1/22 ! interface GigabitEthernet1/23 ! interface GigabitEthernet1/24 ! interface GigabitEthernet1/25 ! interface GigabitEthernet1/26 ! interface GigabitEthernet1/27 ! interface GigabitEthernet1/28 ! interface Vlan1 address 10.195.40.1 255.255.255.0 ! interface Vlan10 address 10.195.30.1 255.255.255.0 ! interface Vlan20 address 10.195.41.1 255.255.255.0 ! default-gateway 10.195.40.254 forward-protocol nd ! no http server http secure-server route 10.195.40.0 255.255.255.0 10.195.41.0 ! ! ---------------- 使用putty 进入后 用命令行测试各交换机的vlan均正常,但是使用网线插上交换机无法ping到下面的vlan,只有分配对应口到对应的vlan才能ping通该vlan下的ip地址。现在想要实现ie-4010上任意口都可ping通各交换机下的设备该怎么操作?
4 条回复4
ilay
 description MCC3
 description MCC4
 description MCC5
 no switchport
 description MCC1
 description MCC2
 description MCC6
interface Vlan1
interface Vlan10
interface Vlan20
 forward-protocol nd
no http server
http secure-server
上面是你给的文本格式化之后的显示内容。你跨网段ping不通地址,感觉像是没有启用 ip routing的问题,可以在交换机上先启用 ip routing,然后show ip route检查一下路由信息是否正常
此外最后的route写的也有问题,10.195.40是设备的直连网段,10.195.41也是直连地址段,且你的掩码均为24,也就是10.195.41.0是一个网络地址,并非有效的下一跳,确认一下路由关系吧,如果没有就先删掉。
Switch#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is not set
10.0.0.0/8 is variably subnetted, 4 subnets, 2 masks
C 10.195.40.0/24 is directly connected, Vlan1
L 10.195.40.1/32 is directly connected, Vlan1
C 10.195.41.0/24 is directly connected, Vlan20
L 10.195.41.1/32 is directly connected, Vlan20
不知需要不需要开启静态路由
ip route 10.195.40.0 255.255.255.0 10.195.41.0
ip route 10.195.41.0 255.255.255.0 10.195.40.0
我配了这么俩条。
目前将 Gi1/2分配给了 vlan 20, vlan 20的ip是10.195.41.1 255.255.255.0  。Gi1/2连接一台电脑ip 10.195.41.237 255.255.255.0 10.195.41.1 可以ping通vlan 20下的所有地址,但此台电脑ping不通 vlan 1里的地址。
ip routing也输入了,但总感觉没有启用一样。
在设备show run中检查一下是否包含`ip routing`的配置文本。这条命令非隐式命令,配置后必然会出现在配置文本中。
show ip route显示 gateway of last resort is not set,这个表示设备没有配置默认路由,如果设备访问其他非本地的网段,可能会有问题。
先确认一下ip routing配置把,如果不显示的话再在全局下再尝试配置ip routing命令试试把,我在IE4000系列的datasheet查到最低的lanbase授权也是支持ipv4 路由的,理论可以正常配置使用。
如果确实无法配置ip routing的话,要么确认一下设备服务支持情况,直接开case处理,要么再找其他型号的三层交换机,将网关迁移到其他支持的设备上。
下面两条路由都是设备的直连地址段,没必要再配置静态路由。
Are you ok
Switch>ping 10.195.40.1
Sending 5, 100-byte ICMP Echos to 10.195.40.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
Switch>ping 10.195.41.1
Sending 5, 100-byte ICMP Echos to 10.195.41.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
Switch>ping 10.195.41.105
Sending 5, 100-byte ICMP Echos to 10.195.41.105, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
Switch>ping 10.195.40.10
Sending 5, 100-byte ICMP Echos to 10.195.40.10, timeout is 2 seconds:
通过CLI命令ping下边的设备都能ping到,通过网口只能ping到本网口vlan下的地址。
快捷链接
