Field | Description |
Contact | Contact that triggers the execution of the step. Default is the Triggering Contact, unless another contact is specified. The name of the triggering contact appears next to the Implicit Confirmation step icon in the Design pane. |
Prompt | Prompt played to the caller. |
Timeout (in secs) | Number of seconds without a caller response before confirmation is considered successful. (Usual value is 2 seconds.) |
Interruptible | If Yes, an external event (such as a caller hanging up) can interrupt the step. If No, the step must complete before any other process can execute. |
Continue on Prompt Errors | If Yes, the step continues with the next prompt in the list if a prompt error occurs, or, if this prompt was the last in the list, the step waits for input from the caller. If No, an exception results, which can then be handled in the script. |
