取消
显示结果
搜索替代
您的意思是:
查看次数
38
有帮助
回复
Cisco 12000 系列 sip 和 spa 软件兼容列表那里有查?
aya_weib
sip卡:12000-sip-601 12.0(32)sy13spa卡: spa-1xchstm1/oc3 12.2(33)srd
两个软件版本是否兼容,听说需要打个补丁,不知道相关资料那里能查到?请前辈指教
1 个已接受解答
已接受的解答
HakinXu
hakxu 发表于 2017-1-5 17:06
根据下面的网站看1-Port Channelized OC-3/STM-1是在12.0(5)S版本上就已经支持了:
Supported Line Card ...
你所说的打补丁这个问题可能是指SPA的FPD版本,要与设备使用的IOS版本兼容才行,在上面的网站中Shared Port Adapter FPD Image Packages for the Cisco 12000 Series 部分也写到了:
Field-Programmable Device (FPD) image packages are used to update Shared Port Adapter (SPA) FPD images. If a discrepancy exists between an SPA FPD image and the Cisco IOS image that is running on the router, the SPA is deactivated until this discrepancy is resolved. For additional information on FPDs, including the upgrade process, see the "Upgrading Field-Programmable Devices" section of the Cisco 12000 Series Router SIP and SPA Software Configuration Guide:
http://www.cisco.com/univercd/cc/td/doc/product/core/cis12000/linecard/lc_spa/spa_swcs/index.htm
Note The maximum time to upgrade the FPD images on one SPA is 2 minutes. The total FPD upgrade time depends on the number of SPAs.
Shared Port Adapter FPD Image Package for Cisco IOS Release 12.0(32)SY
The FPD image package that is used to upgrade SPAs on a router that runs Cisco IOS Release 12.0(32)SY is the c12k-fpd-pkg.120-32.S.pkg file.
在原帖中查看解决方案
10 条回复10
HakinXu
one-time
Level 13
Level 13
感谢您的提问,稍后会有小伙伴为您解答的!:):handshake
fortune
我在官网查到是 IOS XR 3.2 和3.5 支持, 后面问思科SE 说EOS了 没问到
HakinXu
根据如下网站信息看上述硬件在12.0(33)S版本上开始支持:
http://www.cisco.com/c/en/us/td/ ... 1233s/12sovsip.html
http://www.cisco.com/c/en/us/products/collateral/routers/12000-series-routers/product_data_sheet0900aecd80465682.html
问题中的2个版本也就支持这些硬件,不知道你说的兼容是不是这个意思。
aya_weib
http://www.cisco.com/c/en/us/td/ ... 1233s/12 ...
首先,非常感谢两位的回答。
看资料从12.0(33)S版本,12000-sip-601开始支持1-Port Channelized OC-3/STM-1 SPA。
那目前我这块板卡版本为12.0(32)sy13 ,是不是就说不支持spa-1xchstm1/oc3这块子卡?
那么就需要打补丁,补丁是给谁打?子卡、母卡还是把整个系统升到12.0(33)S版本?
小白,问题比较多,请不吝赐教。
HakinXu
aya_weib 发表于 2017-1-5 16:43
首先,非常感谢两位的回答。
看资料从12.0(33)S版本,12000-sip-601开始支持1-Port Channelized OC-3/ST ...
根据下面的网站看sip-601在12.0(32)S上开始支持,1-Port Channelized OC-3/STM-1是在12.0(5)S版本上开始支持了:
Supported Line Cards for the Cisco 12000 Series Routers - >> Channelized Edge Line Cards—Optical Carrier (OC) and T3 部分:
http://www.cisco.com/c/en/us/td/ ... SYrn.html#wp2778642
aya_weib
根据下面的网站看sip-601在12.0(32)S上开始支持,1-Port Channelized OC-3/STM-1是在12.0(5)S版本上开始 ...
谢谢你的热情帮助,Cisco 网站的资料还是很强大,对于初学者还是有点无从下手查找的感觉。看来以后还要多多学习;P
HakinXu
aya_weib 发表于 2017-1-6 08:58
谢谢你的热情帮助,Cisco 网站的资料还是很强大,对于初学者还是有点无从下手查找的感觉。看来以后还要多 ...
嗯,因为你关注的是某个卡或者某个版本,所以你在搜索的时候可以专搜这个卡或者版本的release note,这样就简单多了:lol
one-time
Level 13
Level 13
hakxu 发表于 2016-12-26 13:07
你所说的打补丁这个问题可能是指SPA的FPD版本,要与设备使用的IOS版本兼容才行,在上面的网站中Shared Po ...
恭喜您被提问用户标记为最佳答案!奖励您20积分(已发放给您了),感谢您对思科服务支持社区的支持!
Xin Lei
学习ing:lol
快捷链接
