Duo V4 SDK C# with .Net framework 4.5.2 website
satheeshm
I want to implement Duo MFA authorization into my asp.net website (4.5.2 framework), does Duo V4 SDK supports this framework version?
DuoKristina
The readme at GitHub - duosecurity/duo_universal_csharp: Duo two-factor authentication for .NET web applications states
This library requires .NET Core 3.1 or higher, or .NET Framework 4.7.1 or higher
While the Duo v2 .NET SDK does work with 4.5.2, all of our v2 SDKs will be deprecated in favor of the v4 SDKs, so you would eventually need to migrate to the v4 SDK with its attendant .NET requirements anyway.
Duo, not DUO.
Got it, thank you. Any idea on when is the support going to end for V2?
Satheesh
Not yet, but we will provide at least 18 months support after the deprecation announcement.
The Universal Prompt update guide will have details on the v2 end of life once known:
Traditional Prompt End of Support.
Duo, not DUO.
