How to change duo title and reregister divice again?
enamul-haque
Hi Sir,
I am using Duo Auth Api using enroll & auth . I need to change title duo mobile pop up. Another if I uninstall duo mobile after register. how to re-register the device again?
  1. Change title(Are you logging in CityLive_System API)
I need to change title (Are you logging in CityLive_System API). Here is my image :
How to change mark title?
Re-register device again in same user
I user uninstall duo mobile and install again to use duo mobile , request not showing.
How to re-register device again in same user?
Is there any API?
Please help me?
DuoKristina
Re: changing the title
In the UI the "CityLive_System API" information is the name of your application in Duo. To change that information, log into the Duo Admin Panel and update the name of the integration. You cannot change the "Are you logging in to" text.
https://duo.com/docs/protecting-applications#type-and-name
The application name could also be changed via the modify integrations Admin API endpoint: https://duo.com/docs/adminapi#modify-integration
Re: re-register device for same user
You can reactivate Duo Mobile for a given user's attached phone device by logging into the Duo Admin Panel, viewing the properties of the user's phones or individual phone, and clicking the "Reactivate Duo Mobile" link.
https://duo.com/docs/administration-users#activating-duo-mobile
You can also create and send Duo Mobile activations via the Phones Admin API endpoint: https://duo.com/docs/adminapi#create-activation-code
Duo, not DUO.
DuoKristina
Duo, not DUO.
