I'd like to trigger a DUO prompt without running js
WinstonianSimth
We have a website which is protected by duo. I would like to access it in a context where there is no browser - just a console app. When the attempt is first made, I’d like to trigger a duo push to the user attempting to log in.
So nothing big - just trigger the push automatically rather than waiting for the js to be loaded.
You would need to implement support for this using our AuthAPI. Duo’s WebSDK will only work in a web page.
Duo, not DUO.
mkorovesisduo
Level 4
Level 4
Hi there, would our Auth API be able to accomplish what you’re after?
I don’t see anything in there that would send the DUO login prompt. (I have all the information available to set up the signed request, etc, but I don’t have a web browser.)
Duo, not DUO.
