Issues-DUO in Splunk (Empty Location Details and Incorrect IP Field)
varun-kumar
Hi Team,
We have successfully onboarded DUO logs into the Splunk SIEM platform. We are polling the DUO API to retrieve the necessary logs and have installed the Splunk DUO Add-on to extract the required fields.
While all the DUO logs are being ingested into Splunk, we have encountered two issues:
1) The Location details are appearing as empty.
2) The IP field is showing the Initiator IP rather than the Responder IP (the phone IP **bleep** where the DUO push is approved).
Could you please confirm whether this is functioning as designed, or if we need to adjust any settings to display the details mentioned in points 1 and 2? Additionally, let us know if we need to submit an enhancement request
Please see the attached screenshot for reference. Any assistance in resolving these issues would be greatly appreciated
VK
0 Replies 0
