Rate Limit for Admin API python SDK
pulkit-jain
Community Member
I am using duo_client python SDK for fetching authentication, telephony and admin logs. I want to know what is rate limit for respective methods in SDK (get_authentication_log, get_administrator_log, get_telephony_log). I am seeing that we are hitting 429 at random intervals. Is there any documentation around rate limit for the SDK
This was also asked here: https://community.cisco.com/t5/apis/quot-limit-quot-in-cisco-duo-admin-api-logs/td-p/4963432
tl;dr: The docs for the Admin-API specify that for most logs "there is an intentional two minute delay in availability [...] We recommend requesting logs no more than once per minute."
And in the other thread it's suggested that the rate-limit is then essentially 1-2 requests per minute.
Not sure why Duo doesn't just publish the rate limit info, but as a Duo customer you might get a more concrete answer if you just create a ticket with them?
(https://help.duo.com/s/cases)
Please mark helpful answers & solutions
