3rd span session in APIC not working
nomair_83
We are trying to configure 3rd access span in APCI but its not working i.e. destination port not showing any traffic and giving below error, other two span are working fine.
F1201
Severity:
major
Last Transition:
2017-07-04T12:44:17.455+04:00
Lifecycle:
Raised
Affected Object:
topology/pod-1/node-103/sys/span/session-infra_DMZ-MAILMARSHALL-SRC-1_DMZ-FIREEYE-DST_DMZ-Fire-eye/ldst
Description:
Span destination is in failed state, reason No operational src/dst.
Explanation:
This fault occurs when span destination goes to failed state
Recommended Action:
To recover from this fault, try the following actions
Look at any configuration issues
Verify the configuration is correct/complete
Reduce the number of span sessions and retry
 Any idea why its not working ?
micgarc2
It is possible you are exceeding the number of SPAN sessions we support. How many SPAN sessions do you have? We only support 4 unidirectional spans, and bi-directional counts as two. If you are exceeding this, I recommend you shut down the other sessions and stay within the limit of 4.
Michael G.
Thank you for participating in the Cisco Support Forum for ACI! If you have other questions related to this post, please let us know. If this response answers your questions, please mark this post "answered" and assign a rating to the response(s) provided. This will help notify other viewers that your question(s) is answered and this helps us provide better responses for this and future questions.
russhe
What is the destination for your SPAN? The fault above would lead me to believe something is wrong with the dest you have chosen. What traffic are you trying to SPAN? What is your destination?
If it is a number of SPAN issues, we can verify the number of sessions in the fabric from an APIC via the following commands:
show monitor access session
show monitor fabric session
show monitor virtual session
show monitor tenant __(tenant name)__ session
Are the other two SPANs you have configured on the same leaf as the 3rd you are trying to deploy? As Michael mentioned, this would not be supported on the same leaf if they are bidirectional. Here is the scalability guide for your reference:
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/aci/apic/sw/2-x/verified_scalability/Verified_Scalability_2_0_x.html#id_25871
I am also attaching a PDF on configuring SPAN in the fabric that goes through how to configure it along with what traffic is captured by the different SPAN types
