ACI and network diagramming
stevemadel
I have been tasked with creating a network diagram for our ACI environment.  2 questions for everyone.
1.  Does anybody have any visio stencils for mapping out Tenant->Context->BD->AP->EPG relationships?
2.  How would you diagram an EPG that is in one tenant, using a bridge domain from another tenant, and also the other tenants context?
Thanks in advance!
RedNectar
Hi stevemadel,
Sorry, cant help you there.
Maybe this will help
In this case the 192.168.100.5 is a DNS and DHCP server for both Your_Tenant EPGs
I hope this helps
Don't forget to mark answers as correct if it solves your problem. This helps others find the correct answer if they search for the same problem
RedNectar aka Chris Welsh.
RedNectar
Hi stevemadel,
I hope this helps
Man this is great.  Are you the same RedNectar that runs the rednectar.net blog?  I love it.  We have adopted your naming convention here at work.  I bet I could have found this info there huh.  Either way, thanks for the design tip.  I spent pretty much all day yesterday diagramming our current ACI environment.  Couldn't have done it without your answer.
Thanks for the accolades. And glad you like my blog that I can't identify due to rules of the forum.
I get it man. Seriously though. Was very helpful. I still wonder why Cisco hasn’t released stencils for aci.
