ACI CIMC configuration Without APIC reboot
Networker0
Hello team,
I missed the configuration of the CIMC, is there any way to configure it without rebooting APICs and without impacting Production environnement.
Thnx.
Robert Burns
The only way would be to connect the IMC interface to a switch offering DHCP (assuming it's still in the default mode), then identify the assigned IP and connect to and reset it to whatever you like.
Alternately, you should be able to reboot an APIC without harming anything especially if you have a cluster of 3 or more.
Robert
