ACI Contract
AirBorn
Can someone tell me if my uderstanding regarding the 2 options Reverse Filter Ports and Apply Both Direction found in subject configuration is correct ?
A/ Reverse Filter Ports option: unchecked ; Apply Both Direction:checked
      - Return traffic from Provider to consumer is not permitted, unless a reverse filter is created manually
      - Access from Provider to consumer (new sessions) is not permitted, unless a reverse filter is created manually
B/ Apply Both Direction:Unchecked
       - Access from Provider to consumer (new sessions) is not permitted, even if a reverse filter is created manually. If this
          behaviour is correct, what should be done to permet access (new session) from Provider to consumer? should we creat
          another contract in the opposite direction ?
15 Replies 15
Thanks @RedNectar
