ACI Default self-signed SSL Certificate/Keyring for fabric APIC
Nilay Patel
In past, we never renew manually. Is it automatically renew it self. Do we need to regenerate the key-ring?
jiarchen
HI, Nilay
Thank you for your question.
APIC SSL certificate is used for communications within the fabric.
When the certificate is expired, connections will be insecure, but won't lose access to APIC GUI and there won't be any impact. Self-signed certificate (SSC) gets renewed automatically once it has expired, however, it will take some period to get updated automatically. If the expiration was for more than 2 weeks, further investigation is needed.
If you find my reply solved your question or issue, kindly click the 'Accept as Solution' button and vote it as helpful.
You can also learn more about Cisco ACI through our live Ask the Experts (ATXs) session. Check out the ATXs Resources [https://community.cisco.com/t5/data-center-and-cloud-knowledge/cisco-aci-ask-the-experts-resources/ta-p/4394491] to view the latest schedule for upcoming sessions, as well as the useful references, e.g. online guides, FAQs.
Best Regards
Lucy
jiarchen
HI, Nilay
Best Regards
Lucy
