ACI drops SAN Node while reboot
thiru.vel10
Level 5
Level 5
Enabled data plane learning in Cisco ACI for SAN node associated EPG/Bridge domain arp flood enabled . However experiencing drops when the SAN node get  moved to another host ( MAC address with. Change ). We can reach the nodes ip from same subnet but not reachable from outside Network after 25 mins the node came on line .
Node is not detected as rouge endpoint in ACI .. anyone having this issue
micgarc2
There could be a number of things happening here. I assume the SAN node sends some type of GARP or RARP message to update its new location when its moved or some mechanism similar as how a vmotion would work. If it is unreachable from outside the ACI fabric I would check if the borders leads are learning the SAN nodes new MAC address properly and the tunnel learn is pointing to the new location where this was moved. A TAC case might not be a bad idea here if it is hard to track down.
Tried with Cisco tac case , they suggested to add vip ip into  EPG but doesn't help
