ACI L3OUT + VPC + SVI and static routing
Hi everyone,
I have read some ACI routing configuration guides, but i don´t find any about how to configure static routing in external routing domain.
I have a VPC connected to two 6500, I have configure an external L3 out in the tenant common and I have associated the vPC  (LEAF 1 and Leaf 2) in the interface profile. I have configured the vlan 600 and two ips for site A and B (I suppose they are the two interface vlan for each leave) and the same IP in Secondary site A  and B. I haven´t marked any routing protocol for that I understand ACI will use static routing.
The questions:
  1. I want to set the default route (0.0.0.0/0) with next-hop the 6500´s IP, Where can I configure the static route?
  2. If I don´t marked any dynamic routing protocol, am I using static route?
  3. How I want to use static routing, do I need to configure the Logical node profile with his ID (IP)?
If you go to your L3out profile -> Logical Node Profiles -> Expand the node profiles -> Configured Nodes -> select one of the nodes, you'll see the panel where you can add static routes.
Peter
dodgerfan78
This is in the Node profile, there is a section for static routes. Are your 6500 in a VSS? If not, I would use dynamic routing to each of them.
thanks dodgerfan,
Yes 6500 is in vss for that I configured VPC.
I had to set node profile ID with ip 1.1.1.1, and 1.1.1.2, but what does these id mean?, I have configured the static route not dynamic routing.
Do you known the URL where explain how to configure a static route?
Thank you very much
Peter
