ACI leaf switches are not discovered anymore after a factory reset
driss JABBAR
Hello Community,
Our ACI starter-kit was working fine until i decided to do a factory reset and start the config again from the scratch.
My problem now is that our leaf switches are not discovered anymore by the apic did some check and i can confirm that my leaf has the apic as an LLDP neighbor but apic can't see any leaf as lldp neighbor.
My ACI version is 2.2(2i).
The reset has been executed on the apic as well as on all fabric switches
any advice will realy be appreciated
16 Replies 16
Please Try running:
setup-clean-config.sh <firmware image>
then "reload" on each Leaf & Spine Node starting with the leaf nodes connected to the APICs.
Thanks!
T.
That was my first option before posting the problem here.
