aci microsegmentation without vmware integration
CSCO12550173
Level 2
Level 2
Hi experts,
i have a doubt about useg
if you have only one interface connected to a vcenter-esxi host and its a VDS to a leaf device
and you want to enable useg with a physical dom, because there is no a vm integration only with ip address or mac
because i searched and the only think is mention is when this integration is on
but no no info when this is off and you only have trunks interface from the vcenter to the leaves
Sergiu.Daniluk
Hi @CSCO12550173
If there is no integration with VMware vCenter, and you are using plan vlans on your VDS, then the uSeg will only take effect on the routed traffic. This is because the switched traffic in the same vlan (port-group) will be locally switched by the VDS.
However, you can use isolated vlans on your VDS. This way all traffic can basically be forwarded to ACI Leaf, and the traffic can be policy enforced.
Note: you will need to configure both MAC and IP as attributes for your uSeg - MAC for switched traffic segmentation and IP for routed traffic.
Stay safe,
Sergiu
Sergiu.Daniluk
Hi @CSCO12550173
Stay safe,
Sergiu
Hi Sergiu, hope you are doing fine
thanks for the response i ll test it in a lab environment to see all the phases that the clients need it
thanks for your reply
