ACI Multi-Fabric DCI with VXLAN/EVPN
bmartin10971
In my ACI test environment I have 2 Fabrics each with the following (1-9364C spine, 2-93180YC-EX leaf nodes, 1 APIC - 3.1.1 code). I have both fabrics up and functioning. I now want to experiment with VXLAN/EVPN DCI to connect the 2 fabrics and extend both layer2/3 between them. ( I do not want to use ACI's new Multi-Site setup for the DCI in this use case).
I have added 2-93180YC-EX NX-OS 7.0.3.I7.(3) code switches between the fabrics to configure establish the DCI connectivity.
Based on the documentation that I have been able to find, it appears that this is a supported DCI on this platform, but I am struggling to find any real examples of this configuration for this setup.
Can anyone tell me if this is in fact a supported configuration? If so, would you be willing to share some good examples/docs/videos of how I would configure the VXLAN/EVPN DCI on the NXOS 9K's
Physical Topology Example:
ACI Fabric 1 ----- NXOS Switch 1 ----- 10G WAN Link(s) ----- NXOS Switch 2 ----- ACI Fabric 2
0 Replies 0
