ACI Multi-site TEP pool and infrastructure VLAN
David Yang
Quick question about the ACI multi-site implementation. Is there any implication if the sites used the same TEP pool IP space or infrastructure VLAN ID?
David
micgarc2
https://www.cisco.com/c/en/us/solutions/collateral/data-center-virtualization/application-centric-infrastructure/white-paper-c11-739609.pdf
"Note: The TEP pool prefixes used within each site do not need to be exchanged across sites to allow intersite communication. Therefore, there are no technical restrictions regarding how those pools should be assigned. However, the strong recommendation is not to assign overlapping TEP pools across separate sites so that your system is prepared for future functions that may require the exchange of TEP pool summary prefixes"
