ACI MultiPod - 1 L3OUT per Site OR 1 L3OUT Across Pods
Ibrahim Jamil
Level 6
Level 6
Hi Freinds
L3OUT Q
1. when we design Multipod , what is the Recommendation with regard to L3OUT ? 1 L3OUT per Site OR 1 L3OUT Across Pods , pls note that is Active/Active  Span Ether channel cluster FW across Pods ,
VMM Q
2. with regard to VMM , what is the Recommendation , 1 VMM per Site OR 1 VMM across sites
ServiceChain Q
3. we are planing to use Service chain (FW + SLB) , How the Design looks like ?
thanks all
Ibrahim
Ali Aghababaei
Hi @Ibrahim Jamil
L3OUT Q
Based on  pages 57 and 58 of Cisco Live BRKDCN-2949 document which you can find it on this link (https://www.ciscolive.com/c/dam/r/ciscolive/global-event/docs/2023/pdf/BRKDCN-2949.pdf)
Local L3Outs preferred over L3Outs in remote pods
Remote pod L3Out may be used if it has a better external metric
Also You will find it useful (Pages 67-68)
Please mark answers as correct if it solve your problem.
Ali Aghababaei
Hi @Ibrahim Jamil
VMM Q
2. with regard to VMM , what is the Recommendation , 1 VMM per Site OR 1 VMM across sites:
I found the below information useful in ACI Advanced Monitoring and Troubleshooting book which you can find here :
https://www.ciscopress.com/store/aci-advanced-monitoring-and-troubleshooting-9780135264720
Pages 327-330
AliAghababaei_1-1718899280797.pngAliAghababaei_2-1718900188576.pngAliAghababaei_3-1718900269496.png
Ali Aghababaei
Hi @Ibrahim Jamil
ServiceChain Q
First of all at this time, it seems you can chain UP to 5 services:
Also you can watch this video, I'm sure it will be helpful:
https://www.youtube.com/watch?v=VeWbOl31UIM
Cisco ACI™ provides the solution for high performance, massive, scalable data centers across any geographical location with centralized management and consistent security and telemetry policies. Cisco ACI policies define multitenancy, security, telemetry, and service chaining in the fabric. A ...
Ibrahim Jamil
Level 6
Level 6
Hey Ali
Thanks a  lot seems helpful , kindly follow my ACI Posts,Questions
