ACI PBR traffic issue
deepakbalan
Same Tenent --two EPG in different VRF --Unicast routing enabled, Advertise externally, Shared between VRF
PBR inserted for both the EPG
Endpoint A Tenant-A:VRF_1:EPG_1
Endpoint B Tenant-A:VRF_2:EPG_2
Endpoint C Tenant-A:VRF_2:EPG_2
EP A--> B is working fine  traffic flow
EP A->FW1->ACI-GW->FW2-> EP B
EP A--> C is not working fine  traffic flow
EP A->ACI-GW->*->*->*
traffic is not coming out correctly not even reaching the firewall, how to troubleshoot it any suggentions
Sergiu.Daniluk
Hi @deepakbalan
What is the difference between EP-A -> EP-B vs EP-A -> EP-C flows?
Example of differences:
+ EP-B is located on different leaf
+ EP-B and EP-C are in different subnets
Do you experience same problem if you use a different source other then EP-A to verify the redirects?
Can you also share a logical topology?
For troubleshooting you can start by installing ELAM assistant and verify what is the result of the packet forwarding on the first leaf:https://dcappcenter.cisco.com/elam-assistant.html
Sergiu
EP->B,C are in the same subnet but a different leaf, ,The problem got resolved after removing the VRF and adding the same.
Another issue  APIC GUI data display
when user B configures the subnet in the BD, user A can't see the same in same APIC GUI, but can be see in  CLI route as unicast routing is enabled(show ip route) , logged out and checked, browser cache cleared and still the same. how to fix it
