Check heatbeat from HAL process
andre.godoy
Hey Guys,
I'm facing the bug CSCvo45816,  where the switch has been up for a long time (607 days in my case). Once our timer (32-bit integer) wraps around, the Hal process will see this as a missed heartbeat and reload the switch.
The workaround is run  "vsh_lc -c 'debug platform internal hal infra thread heartbeat disable'" in all leafs.
Do you guys know how I can confirm if the thread heartbeat was disabled?
Thank you!
andre.godoy
I recently had this answer
On the leaf, with root privilege,
cat /var/sysmgr/tmp_log/csco_hai_sb255_svc12_wk0_nub.log | log_decode | tail
If it's enabled, you will see the "punched HB" logs regularly. OR if it is disabled, you will see no output…
Jun 22 2019 CDT 19:20:16.495542[INF][TXT][sb:255-svc:12-wk:0] [HB] - Monitoring thread health
Jun 22 2019 CDT 19:20:16.495565[INF][TXT][sb:255-svc:12-wk:0] [HB] - thread sb:255-svc:7-wk:0 punched HB
Jun 22 2019 CDT 19:20:16.495577[INF][TXT][sb:255-svc:12-wk:0] [HB] - thread sb:255-svc:13-wk:0 punched HB
andre.godoy
