ACI-Pre-Upgrade-Validation-Script CIMC and space errors
irenof
Hi all,
I am going to uprade an ACI fabric from release 4.2(4i) to 5.3(2d).
I checked the release notes for APIC 5.3 (link) and I verified that my current CIMC version (4.0(1a)), although it is not the recommended, is in the list of the compatible ones.
I run the ACI-Pre-Upgrade-Validation-Script to check all the stuff, and I got 2 "FAIL - UPGRADE FAILURE!! "
1) about CIMC version
but 4.0(2f) is not in the list in the 5.3 rel notes link i posted..
I was asked to do the minimum necessary to upgrade, so I would not upgrade the CIMC if not manatory needed.
2) space
But i only have 4 images (2 for current version and 2 for target 5.3(2d)), so I cannot delete anything (I do not want to remove the images of the current release..). Btw, this partition I think that will not be involved in the upgrade...
What should I do?
Can I proceed with the upgrade, or  not?
AshSe
Hey @irenof
@irenof wrote:
Hi all,
From the link: Miscellaneous Compatibility Information
Supported Release:
  • 4.1(1d) CIMC HUU ISO for UCS C220 M5 (APIC-L3/M3)
ACI-Pre-Upgrade-Validation-Script is recommending you to have 4.0(2f). I would personally recommend to follow the recommendation [4.0(2f)]. But please do consult with Cisco Tac beforehand.
2) space
What should I do?
IMHO,
  • You should free the space as consumed by fault (F1527)
  • Check and monitor to make sure fault doesn't reappear.
  • If fault reappears; fix the cause of the fault, clear, and check again
Please do open a SR and seek Cisco Tac's advice before any change.
Hope This Helps!!!
AshSe
Forum Tips:
  1. Insert photos/images inline - don't attach.
  1. Always mark helpful and correct answers, it helps others find what they need.
  2. For a prompt reply, kindly tag @name. An email will be automatically sent to the member.
