Contracts are not apply or submit on APIC
moj_ccie
Hello everyone.
We are using vAPIC 6.0.5 with some C93180fx & C9332c as spines.
Everything works fine, but when I create contact (in Application Profile-Topology), I cant submit & apply contact to my EPGs !
As a tip, when I create a contract, the contract lines and arrows are not displayed either - meanwhile ESG/ Preferred Group and other tools are working properly...
Is there a mis-config or is the feature/option disabled?
Many thanks.
AshSe
Hello @moj_ccie
As a first thought, your problem seems to be related to Cisco Bug ID CSCwf55317
Note: You need partner level access to check Cisco Bug ID
Hope This Helps!!!
AshSe
Forum Tips:
  1. Insert photos/images inline - don't attach.
  2. Always mark helpful and correct answers, it helps others find what they need.
  3. For a prompt reply, kindly tag @name. An email will be automatically sent to the member.
AshSe
Hello @moj_ccie
Hope This Helps!!!
AshSe
Forum Tips:
moj_ccie
I've already checked the mentioned bug.
You got it exactly right -
thanks for your detailed guidance.
