ACI - QSFP 40Gbps - Very high Temperature inside a N9K-C93108TC-EX
ju.mahieu
My DC Ops team are reporting that our QSFP-40G-SR-BD inside Nexus 9000 C93108TC-EX are very hot. Too hot to take by hand longer than 6 seconds. The OS version running is n9000-12.1(1h).
The temperature is normal if we put the same SFP inside a N9K-C93180YC-EX.
Could we consider this temperature level as normal state ? Do you have the same behaviour in your own devices ?
Thank you
Ju
leaf103# show environment temperature
Temperature:
Module   Sensor                       MajorThresh   MinorThres   CurTemp     Status
                                      (Celsius)     (Celsius)    (Celsius)
1        Inlet(1)                      70            42           30         normal
1        outlet(2)                     80            70           36         normal
1        x86 processor(3)              90            80           53         normal
1        Sugarbowl(4)                  110           90           58         normal
1        Sugarbowl vrm(5)              120           110          58         normal
1        10G PHY 1(6)                  110           110          46         normal
1        10G PHY 2(7)                  110           100          44         normal
1        10G PHY 3(8)                  110           100          42         normal
1        10G PHY 4(9)                  110           100          43         normal
1        10G PHY 5(10)                 110           100          43         normal
1        10G PHY 6(11)                 110           100          41         normal
1        10G PHY 7(12)                 110           100          41         normal
1        10G PHY 8(13)                 110           100          41         normal
1        10G PHY 9(14)                 110           100          40         normal
1        10G PHY 10(15)                110           100          46         normal
1        10G PHY 11(16)                110           100          49         normal
1        10G PHY 12(17)                110           100          54         normal
leaf103# show interface  Ethernet1/49 transceiver sprom
Ethernet1/49
    transceiver is present
    type is QSFP-40G-SR-BD
    name is CISCO-AVAGO
    part number is AFBR-79EBPZ-CS2
    revision is 01Bh
    serial number is AVM2025U0TV
    nominal bitrate is 20600 MBit/sec per channel
    Link length supported for 50/125um OM3 fiber is 100 m
    cisco id is -- 13
    cisco extended id number is 220
DOM is Disabled
  Identifier                      : 0x0d (QSFP+)
  Ext_Identifier                  : 0xdc
  Connector                       : 0x07 (LC)
  Infiniband Compliance Code      : 0x00 (None)
  Sonet Compliance Code           : 0x0000
  Gigabit Ethernet Compliance Code: 0x00 (None)
  Encoding                        : 0x05 (64B/66B)
  BR_Nominal                      : 0xce  [20600]
  Reserved1                       : 0x00
  Length_SMF                      : 0x00  0 KM
  Length_OM3                      : 0x32  100 Meters
  Length_OM2                      : 0x00  0 Meters
  Length_OM1                      : 0x00  0 Meters
  Length_Copper                   : 0x00  0 Meters
  Reserved2                       : 0x00
  Vendor Name                     : CISCO-AVAGO
  Reserved3                       : 0x00
  Vendor OUI                      : 0x00176a
  Vendor Part No                  : AFBR-79EBPZ-CS2
  Vendor Revision                 : 01Bh
  Reserved4                       : 0x07d046
  Check Code ID                   : 0x48 (OK)
  Options                         : 0x0000
  BR Max                          : 0x0f
  BR Min                          : 0xde
  Vendor Serial No                : AVM2025U0TV
  Date Code                       : 160620
  Diagnostic Monitoring Type      : 0x08
  enchancedOptions                : 0x00
  SFF8472Compliance               : 0xf5
  Check Code EXT                  : 0xd5 (OK)
  Vendor Specific ID Data         : 0xf50006e8f42971c5579ca988e5020898
                                  : 0x2e52430000000000000000008a1c5861
5 Replies 5
Manish Gogna
Hi Ju,
It looks to be within normal range as per the following
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/transceiver-modules/data_sheet_c78-660083.html
Environmental Conditions
Operating temperature range:
●   Commercial temperature range: 0 to 70°C (32 to 158°F). Exceptions are
◦     QSFP BiDi (QSFP-40G-SR-BD): +10 to 70°C (50 to 158°F)
◦     QSFP BiDi Monitor (QSFP-40G-BD-RX): +10 to 70°C (50 to 158°F)
◦     QSFP LR4 Lite (WSP-Q40GLR4L): +10 to 60°C (50 to 140°F)
Manish
Thank you Manish for your answer.
Ju
Ju,
I've noticed the same issue with two similar models with one variant- specific to the airflow direction
The QSFPs are:
1) Too hot on my Nexus 9000 C93108TC-EX *** with Port side exhaust ***
2) Normal (warm) on my Nexus 9000 C93108TC-EX *** with Port side intake ***
3) Normal (warm) on my Nexus 9000 C93180TC-EX *** with Port side exhaust ***
What is your airflow ?
Amit
Hi Amit.
I confirm my nexus are provided with port side exhaust.
Thank you for that clarification.
Ju
Hi Ju,
Its strange because on we don't have similar issues on our other 9Ks with PE.
Did you ever escalate to TAC ? I'm curious if this could be related to the PE airflow on this particular switch.
Also, have you ever had any service issues - high temp alarms, or tranceiver failures ? I see that that your original post was from 2017.
-Amit
