ACI Remote leaf - Encapsulation value 4 collides with INFRA
alooky_89
Hi All
we have ACI single POD deployment and we are implementing Remote leaf during the configuration through the wizard got this error: Encapsulation value 4 collides with INFRA
since we are using VLAN 4 as infra VLAN for our ACI POD so the question is:
If we are using VLAN-4 as infra VLAN; will remote-leaf work? What is the impact ?
is it supported?
AshSe
Hi @alooky_89  any reason you are not using VLAN 3967 (Cisco suggested) for Infra VLAN?
Can you please change to 3967 and check.
Hi @AshSe this ACI deployed 4 year ago and the infra VLAN used is VLAN 4 for no reason by chance,
Can you please change to 3967 and check. Unfortunately its NOT possible since we need to wipe the ACI and configure it again, Unless you have another way to change it
Hi @alooky_89  are you using VLAN 4 (Single or as in range) in you Access Policy configuration?
