Add IGMP Group Address to ACI BD for Testing
zachartl
I have a BD configured for PIM with IGMP / IGMP Snooping Policies. I need to test this functionality as I'm working with some Vendors. Is there a way I can add a TEST IGMP Group to a BD interface, similar to this method? i.e. (config) int vlan 280 ; (config-if) ip igmp join-group 230.230.10.1 ; exit ; exit
Thank you,
Terry
Sergiu.Daniluk
Hello @zachartl
Yes you can do that, but it's per EPG, not BD. You can add an IGMP static group in the static path:
Stay safe,
Sergiu
Sergiu.Daniluk
Hello @zachartl
Stay safe,
Sergiu
Hey Sergiu,
Right as Rain! I really appreciate the assist with that.
Thank you Sir!
Best Regards,
Terry
