APIC controller storage capacity
Xiao Guai
When I was investigating the storage capacity of APIC,
I found that the storage is being on increase in the capacity of /data/log/.
Currently, the GUI displays 53%, but I'm afraid that something problem could affect the system because of the storage capacity lack in the future.
Would it be possible for you to answer the following points?
・For each partition of APIC, what percentage will cause an error to be displayed?
 And if an error occurs, what files should I delete?
・If the capacity of some partitions such as /data/log runs out, will there be any impact on the system?
・What logs are stored in the /data/log and /logs partitions?
Thank you
0 Replies 0
