APIC. Is there any way to figure out flapping interfaces in the fabrci.
atcapaev
Hello Experts.
Could you help me on the following? I have to find flapping interfaces in the fabric.
Theoritically I can do it in ugly way which is run a script which will execure show interface on each node of the fabric and then run a condition if last link flap <= 5 mins then it's problematic interface.
However, I believe there is much more elegant way to find such interfaces using moquery.
Could anybody tell me if he/she had to use it before?
Any suggestion will be highly appriciated.
2 Accepted Solutions
Remi Astruc
You can use the following moquery by adapting the timestamp field:
moquery -c eventRecord -f 'event.Record.cause=="port-down" and event.Record.created>"2019-06-11T08:40:00"' | grep affected | sort
The "<=5min" might be difficult to implement in a single moquery but instead should be integrated in a script to automatically generate the timestamp "current time minus 5 minutes" and fill the moquery field.
Remi Astruc
Yes, it will cover even sub-second cuts.
An event is similar to a log entry. It can notify about issues but also informational things.
A Fault represents a faulty status of an object at a given time, and can influence Health Scores. A Fault has a notion of lifecycle and its status evolves in time.
Remi Astruc
Remi Astruc
Remi Astruc
Hello Remi,
Thank you very much!
Could you tell me please if the link flapped say for a second, will such thing be accounted as event?
Could you tell me please what could be the difference berween an event and fault.
Remi Astruc
Thank you very muxh Remi!
