BD Multicast address pool using Multi-Site
Hello guys.
I would like to know if when creating the fabrics on a Multi-Site environment, is it possible to use the same BD Multicast pool on both sides or should it be different?
Planning on using the same 225.0.0.0/15 range on both sides.
RedNectar
Hi @Fernando Hernández ,
Yes it is. I have done it.  When multicasts go from one site to the other they end up at the O-MTEP (Overlay-Multicast Tunnel End Point) of the other site and placed on the appropriate Multicast Tree for that site.
I hope this helps.
Don't forget to mark answers as correct if it solves your problem. This helps others find the correct answer if they search for the same problem.
RedNectar aka Chris Welsh.
RedNectar
I hope this helps.
Nice.
We did it on a lab environment, but wanted to be sure cause now we are going to do it on a real productive environment.
Thanks for the help.
