can we use PBR firewall for host communication within same EPG
hashimwajid1
Level 3
Level 3
Hello
we would like to isolate host communication within same EPG and if host want to communicate with other host inside same EPG than this should be done through PBR firewall.
intra EPG communication should be done through PBR firewall so we can control who can talk to who in same EPG
is it possible to achieve ?
You don't need uEPG for this, just a intra-EPG contract + PBR attached to it.
Have a look at the whitepaper I shared above and you will see the technical details.
Cheers,
Sergiu
Sergiu.Daniluk
Yes, you can achieve this by using intra-epg PBR contract.
Check the PBR whitepaper: https://www.cisco.com/c/en/us/solutions/collateral/data-center-virtualization/application-centric-infrastructure/white-paper-c11-739971.html  , section "PBR with intra-EPG contract"
Take care,
Sergiu
Dear Sergiu,
Thanks for response. do we have to configure Micro EPG for this task and then apply contract between micro EPG or is there another way to apply it ?
Cheers,
Sergiu
