04-19-2021 04:42 AM
Hi there
I have one ACI fabric with some configuration done. When i shutdown whole Fabric including APIC Cluster and all switches. Then i power on all them again. All switches remain in Inactive status. Can somebody tell me why?
04-19-2021 04:59 AM
There's not enough information provided to begin to guess. What was the order you powered down/up fabric devices? Which version are you running? Can APIC see the Switches via LLDP? How many controllers?
Robert
04-19-2021 05:13 AM
I shuttdown the apic from the GUI and gracefully. Then I power off the switches.
Apic version is 5.0
Show lldp command shows nothing. I tested it using 1 apic alone and with apic cluster.
04-19-2021 05:20 AM
From the APIC CLI run:
acidiag run lldptool in eth2-1
acidiag run lldptool in eth2-2
Robert
04-19-2021 05:43 AM
Agent instance for device not found 7f
04-19-2021 06:04 AM
Use ifconfig, and find out the interfaces of the APIC used for fabric uplinks. Then repeat the command above for them.
Robert
04-19-2021 05:40 AM
if you connect to each APIC, do you see the same behavior on all of them?
04-19-2021 05:56 AM
Yes. In addition to version 5. I have same problem with vwrsion 4.2.4
any config needed to do for apic faced interfaces?
04-19-2021 06:04 AM
I exactcly do nothing after fabric discovery. Something missed?
