Cisco ACI OSPF Neighbor Failer and INIT state
Translator
Community Manager
Community Manager
I set up OSPF between Cisco ACI N9K-C93180YC-EX switch and C9300-48U switch, but Neighbor state is maintained in INIT and will not be established. I will attach the setting screen as a capture screen. Can you tell me what the problem is? Two Nexus switches have vPC settings그림1.png
5 Replies 5
RedNectar
Hi @Translator ,
Try setting MTU in the L3Out to 1500 bytes.
RedNectar aka Chris Welsh.
I set the MTU to 1500 in SVI, is it different from the L3OUT MTU 1500 you answered?
Hi @Translator ,
No, I was referring to the MTU in the SVI - so we need to look at other options. Have you tried running debug  on the external router?
I checked and it's repeating like this
Hi @Translator ,
OK. I guess you need to double check all those OSPF settings that have to match. I can see that the IPs seem to be on the same subnet, but I can't check (from what you've shown)
  • That the mask /24 at BOTH ends
  • that the OSPF area ID is the same at both ends
And at the very basic level, I guess you've already tested that you can ping from one end to the other.
