Cisco ACI setting port description for leaf ports
Under Fabric-Inventory-Pod x- Leafxxx-Interfaces-Physical Interfaces-Eth1/1 you can add a Description to that port.  Login to the leaf and do a show interface status shows the description.
Is there a way to set this description with ansible or terraform? I have not found a module for this, and I have tried using the rest api. But with no luck.
Has anyone done this?
I would like to be able to set the description with information extracted from dcTrack. Our DC guys does the cabling in our DC's and update dcTrack.  We can extract this information with api and want to use it for descripton as mentioned above.
this seemed to solve the problem:
- name: ACI REST
hosts: localhost
connection: local
gather_facts: no
vars:
validate_certs: no
tasks:
- name: Using REST API with a JSON string
aci_rest:
hostname: 10.166.254.10
username: '{{ username }}'
password: '{{ password }}'
validate_certs: '{{ validate_certs }}'
method: post
path: /api/node/mo/uni/infra/hpaths-201_eth1_1.json
content: |
"infraHPathS": {
"attributes": {
"descr":"apic1"
- name: ACI REST
hosts: localhost
connection: local
gather_facts: no
vars:
validate_certs: no
tasks:
aci_rest:
method: post
content: |
"infraHPathS": {
"attributes": {
"descr":"apic1"
O.K.
you can also use the cisco.aci.aci_access_port_block_to_access_port module, if you wish. I think it looks a bit nicer in the playbook.
Regards.
Oz
