Cisco ACI Solution with Multiple DC
tumarha
Dear All
Just want to discuss about how to deploy Cisco ACI and APIC solution in case of customer has multiple DCs, I am proposing this solution to my customer.
In case of I use N9K x 4 (2 Spine, 2 Leaf) + APIC x3, how do I deploy ACI+APIC on 2 DCs, my questions are
1. From my proposing solution, is it valid to deploy?
2. Do I need L2 Extension between both 2 DCs, if yes, what is the prefer technology (OTV, EoMPLS, or?)
3. Do I need 2 cluster of APIC or I can deploy only 1 cluster of APIC?
4. In case of I need 2 clusters of APIC (1 cluster per DC), how do I manage APIC, does it separate management?
5. If my customer has already use Cisco UCS Director, and if I need 2 cluster of APIC, how do I integrate 2 cluster of APIC and UCSD? (I know 1 UCSD and 1 cluster of APIC are possible but if 2 cluster of APIC, I have no idea)
Please feel free to share any advice.
Thank you very much.
Best regards
Wisit
Martin Lipka
I would recommend o keep it simple and deploy s single fabric (2xSpine, 2xLeaf 1x cluster) per DC.
At this stage I would recommend to connect both fabrics with in redundant fashion utilising any L2 technology and allow VLANs or VXLANs to be shared between both fabric. Soon additional options will be added to your design to simplify this design.
For startres, I would go with the minimum 3xAPIC controlled = 1xAPIC cluster.
It depends what scale you need here. You are increase the amount of APICs in the customer easily in future.
It all depends from your customer requirements. I would recommend to keep it separate but this might change with adding additional functionality in future. If your customer requires full diversity, always keep them separate!
I'm not sure about this.
Dear Martin Lipka
Thank you very much for your information.
Best regards
Wisit
