04-18-2020 05:25 PM
I have a pair of SPAN sessions on 2 ACI Leaf switches but the traffic only appears to be getting captured in 1 direction. I checked the SPAN configuration and it does specify "Both" in terms of direction. Anyone have this issue? It's an older version of ACI (v2) so it could be some kind of bug - just wanted to see if I've missed something in the config. It's a SPAN between ports on the same Leaf switches.
04-18-2020 05:29 PM
Just fyi - actual version is 2.2(1o)
04-19-2020 02:55 AM
Hi @chrisdaly
Just to clarify:
Cheers,
Sergiu
04-19-2020 10:18 AM
Thanks for responding!
-Local SPAN session on Leaf switches
-Looks like all traffic but unicast for sure
-Leaf switches are N9K-C93180YC-EX - firmware n9000-12.2(1o)
04-19-2020 12:07 PM
How many SPAN sessions you have in total on your Leaf switch?
Total number of supported sessions for ALE based switches - including N9K-C93180YC-EX, is:
4 uni-directional or 2 bi-directional infra/tenant sessions
4 uni-directional or 2 bi-directional fabric sessions
Cheers,
Sergiu
04-19-2020 01:08 PM
1 local SPAN on each Leaf switch - SPANs are configured under access policies. Are those limits per Fabric, tenant or per Leaf?
04-20-2020 10:34 PM
The limit is the same as the previously mentioned. Hmm well what you have there sounds either like a bug or a limitation.
I was not able to find anything mentioned in the guidelines and limitations. And reg bugs, this one seems to be affecting your version:
CSCvc11053 - SPAN not capturing incoming traffic on 2nd generation ASIC ACI LEAF Symptom: Incoming traffic is not captured by SPAN or ERSPAN. This is a current limitation in 2nd generation ASIC ACI LEAF (N9K-C93180YC-EX and 93108TC-EX). Conditions: When SPAN or ERPSAN source is configured using a individual port, which is a member of a Port-Channel or a vPC, on 2nd generation ASIC ACI LEAF. Workaround: None. For Local SPAN : Please configure PC itself. If you want to SPAN the vPC, please choose the "VPC Component PC" option. For ERSPAN : Please configure PC itself in case of PC, please configure vPC itself in case of vPC as a source instead of its member port.
Is it applicable for you? Do you span a individual interface part of a PC?
Sergiu
