Cisco Application Centric Infrastructure Simulator Installation
Morning,
I want to know if it is possible to install Cisco Application Centric Infrastructure Simulator on VMWare WorkStation or ESXI. If Yes, whats are Requirements.
Thanks.
26 Replies 26
I tried the same thing, but there is no way to run the ACI simulator without the additional HW.
You have all the info here:
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/aci/apic/sw/1-x/simulator/getting-started/b_ACI_Simulator_Getting_Started_Guide.pdf
I am having this same issue but I have ACI Simulator hardware. C220 M4 running ACI 3.0 and trying to upgrade it to the latest code 3.1.... Gets stuck on No input Moving on.....
Can anyone help with this issue?
Update: finally got it to upgrade, it just took ~5 hours
Last month they published the ACI simulator, it includes 3 APICs, 2 leaf and 2 spine switches:
http://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/application-centric-infrastructure-simulator/datasheet-c78-733252.html
Have a look on dcloud https://dcloud-lon-web-1.cisco.com/dCloud/
But you need CCO credentials
Anser
mengru.tsai
Yes. is possible. Install ACI Simulator on ESXi Server.
hallo mengru.tsai
Can you PM me how to do that?
thanks
Mengru,
can an you please explain how did you manage to install it on ESXi.  You can use the private method as well.
I'm also curios about it, maybe a small tutorial will help
I have the ACI Simulator activated and running. Where can I get instructions on how to use it?
I need to enable external API access and create a small Nexus 9000 Fabric, all into simulator and without nexus real hardware.
Can I accomplish it ?
tomy.tim
Hi @Adon Camille SARAKA , I just made a tutorial with the latest version of cisco aci simulator 6.03d, maybe I can help you. If you have any questions don't hesitate to ask. Link: https://community.cisco.com/t5/application-centric-infrastructure/installation-guide-for-cisco-aci-simulator-6-0-3d/td-p/4991325
translator
click
klik
Double-click
Select to translate
Tomy Tim
