Cisco Multi-Pod Configuration Error
AshSe
Hey experts, while configuring ACI, I am getting Value 4 collision error stating: "Encapsulation value 4 collides with INFRA". I understand that VLAN 4 is a default VLAN used by APICs and gets auto-configured in APIC and the same is used for inter (between Pods) and Intra (inside the same Pod) APIC communication. The same VLAN ID is used to configure "dot1q" encapsulation in IPN devices to ensure the communication (both Intra and Inter) in between APICs. Check the error below:
Please suggest the cause of this error and how to correct it.
Wassim Aouadi
Level 8
Level 8
Hi @AshSe ,
I do not think the error is related to VLAN 4. Can you check whether you configured the external TEP pool for Pod 1 already?
Cheers,
Wassim
Forum Tips: 1. Paste images inline - don't attach. 2. If you find a post helpful, please give it a thumbs up or mark it as a correct solution.
