Showing results forĀ
Search instead forĀ
Did you mean:Ā
Command Clear IP EIGRP Neighbor x.x.x.x soft Cisco ACI Leaf
lathif
Hi everyone,
Is it possible to running command clear eigrp neighbor soft on Cisco ACI border leaf? For example if using NXOS can achieve with command "clear ip eigrp  [eigrp-as] [ip-neighbor] soft". I am using ACI 3.2(6i) version. My case is after upgrade firmware on firewall, core can receive prefix from leaf, but leaf can't receive prefix from core. No filtering/ACL applied on core and leaf. So, I think need command clear eigrp soft on leaf to resync/reset eigrp process but when I check remote to leaf CLI, this command not available.
I check logs on core and leaf regarding eigrp, everything is good.
My topology:
Core N7K<> Firewall PaloAlto (transparent)<> Leaf
Core <[directP2P]> Leaf ---> eigrp peering
- Lathif
0 Replies 0
