Configuration of OOB IP without APIC
suneq
A client asked me to configure the OOB mgmt IP on a few N9K in ACI-OS without any APIC before sending the devices to the DC.
I personnally do not see any advantage of doing that, but I want to know if technically there is a way to do it (without APIC)?
Thanks.
2 Accepted Solutions
Francesco Molino
You can configure oob ip over GUI or CLI but with apic.
Without apic, you won't be able to do it. At least, never tried but i believe there's no solution.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Not possible unless you had root access.
Robert
Francesco Molino
Francesco
Robert
