configuration on Cisco APIC to add it under monitoring with SNMPv2
Noovi
Hello Guys,
what is the configuration on Cisco ACI end with image 5.3(2a) to add in monitoring in Solarwind using SNMPv2
AshSe
Hello @Noovi
1. Configure SNMP Policy (APIC GUI Path):
  • Log in to the APIC GUI.
  • Navigate to Fabric > Fabric Policies > Policies > Monitoring > Common Policy > Callhome/Smart Callhome/SNMP/Syslog/TACACS
  • Right-click and select Create SNMP Source - Name, DestGroup:
  • Provide: Host, Port, Version, Security/Community Name, v3 Security level, Management EPG
2. Configure SolarWinds:
  • SolarWinds Web Console:
    • Log in to your SolarWinds web console.
    • Add the APIC(s) as a node for monitoring.
    • When adding the node:
      • Polling Method: Select "SNMP".
      • SNMP Version: Choose "SNMP v2c".
      • SNMP Community String: Enter the community string you configured on the ACI fabric.
    • Once the node is added, SolarWinds should start polling the APIC using SNMP and display the relevant metrics.
Note: Please verify any modifications in the configuration sequence, as it may differ across software versions.
HTH & Stay Curious!
AshSe
Community Etiquette:
  1. Insert photos/images inline - don't attach.
  1. Always mark helpful and correct answers, it helps others find what they need.
  1. For a prompt reply, kindly tag @name. An email will be automatically sent to the member.
Hello AshSe,
I will check this option but is it possible to share official Cisco document/URL for this task from ACI end?
Hello @Noovi
The requested configuration has been custom-tailored to align with the requirements of version 5.2(5c). However, you can refer to the documentation available at the following links:
https://www.scribd.com/document/578686055/26-Configuring-SNMP-for-ACI-LEARN-WORK-IT
https://learnwithsalman.com/snmp-in-aci/
https://www.dclessons.com/snmp-configuration-in-aci
https://howtoaci.com/2018/12/03/snmp-configuration-in-aci/
HTH & Stay Curious!
AshSe
