03-28-2025 08:23 AM - edited 03-28-2025 08:25 AM
Hi all,
next week I will migrate a FEX from legacy to ACI and so I have to configure Access and Tenant policies. For the Access policies is ok, I found many recources online and I am pretty confident the configuration is working.
Unfortunatley I haven't got a FEX to connect to ACI before the migration, so I cannot test all before the activity.
The other thing have to configure is the set of EPG static binding of the FEX port. What I will have to do?
This is my situation is:
FEX profile : FEX_111_IntProf
Leaf Interface Profile: Leaf_112_to FEX_111_IntProf (with the to fex check box)
Leaf switch profile: Leaf_112_SwProf with a binding to the Leaf_101_to FEX_111_IntProf
Now, immage I have to configure port 101/1/3 as trunk with VLAN ID 103:
I have my EPG: VL_103 (associate to BD) and I want to add a static binding, wille the window show something different for the fields:
- Path type
- Node
- Path
Or port for FEX will appear after the leaf 112 port?
Moreover, I will also have to configure future FEXs in ansible.
In the ansible aci module I see:
And I do not know If I have to choose type "fex" and port like:
- name: Deploy Static Path binding for given EPG
cisco.aci.aci_static_binding_to_epg:
host: apic
username: admin
password: SomeSecretPassword
tenant: accessport-code-cert
ap: accessport_code_app
epg: VL_103
encap_id: 103
deploy_immediacy: immediate
interface_mode: trunk
interface_type: fex or switch_port
pod_id: 1
leafs: 112
interface: '101/1/3' or '1/3'
state: present
delegate_to: localhostThank you!
Solved! Go to Solution.
04-24-2025 04:17 AM
I had access to a FEX on my lab and I tested what I asked, here my results:
- On APIC GUI it is possible configure an EPG static bind for a FEX port just selecting the port from the drop down menu with all the leaf interfaces, as a normal leaf port
- With Ansible it is possible configure an EPG static bind for a FEX port thourgh the variable "extpaths":
The extpaths integer value part of the tDn.
extpaths is only used if interface_type is fex, fex_vpc or fex_port_channel.
When interface_type is fex_vpc, then extpaths is a list with both fex IDs.and then select the port like "eth1/5", the FEX ID, like 112/1/5, will be inserted by the extpaths variable.
This answer my question.
I hope it will be useful to others!
04-24-2025 04:17 AM
