Difference between eltmc and epmc
ciscoaci2015
Hi ACI Team,
Please help to understand the difference between eltmc and epmc in the following command:
module-1# show system internal epmc ....
module-1# show system internal eltmc ....
and difference between eltm, epm and ethpm
leaf1# show system internal <eltm / epm / ethpm> ....
Thanks!
Tomas de Leon
Take a look at:
Troubleshooting Cisco Application Centric Infrastructure
Problem resolution insights from Cisco engineer
http://www.cisco.com/c/dam/en/us/td/docs/switches/datacenter/aci/apic/sw/1-x/Troubleshooting_ACI/Cisco_TroubleshootingApplicationCentricInfrastructure.pdf
The book talks about the commands that you ask about.
Thanks for using the ACI Cisco Support Forum!
T.
Jason Williams
The acronyms you mentioned are processes on a fabric switch.
EPM = Add/Remove/Maintain endpoints
ELTM = Add/Remove VRF/VLAN configuration
ETHPM = Interface state changes
Jason
spaneers
The Ethernet Logical Table Interface Manager (ELTM).
The Ethernet Logical Table Interface Client (ELTMC).
Endpoint Mapper (EPM).
EPM client (EPMC).
ethpm: ethernet policy manager.
Saravanya
RedNectar
If your question has been answered, it is a great idea to mark the question as being answered.  This helps:
  1. others with a similar problem find the correct answer
  2. people who look for "unanswered" questions to answer finding this
  3. prevent your question from becoming a "dead thread"
If it has not been answered, perhaps expand your question to make it clearer exactly what you were expecting (e.g. examples).
RedNectar aka Chris Welsh.
