Enterasys Switch and ACI
apache_le
Does anyone have experience connect an ACI fabric via L2 trunk to Enterasys switches?
dpita
Hello
Thanks for using SupportForums!
i do not have experience with that switch, but if it follows standards it should be a simple matter of trunking a VLAN on ACI and on the Enterasys switch.
You can try either an External Bridge Outside or a static Path under an EPG. In these cases, the Bridge Domain should be set to all flood.
Curtis Parish
We have done this with Enterasys switches.  We also lag (port channel) between two leaves.
"We also lag (port channel) between two leaves"  You mean vPC?  Did you experience any issue between the Entarasys and ACI fabric?
