F1529: Storage on node 1 with mounted at /data2 is 100% full
conf-t
I have a fault F1529 on APIC1 which says that "Storage unit /data2 on node 1 with xxx mounted at /data2 is 100% full" !! But when I try to check data2 folder from CLI, I can't find the files that I can delete and the size of data2 folder is only 89ko ! Any help
@conf-t
 Run this inside the folter
du -h --max-depth=0 * | sort -hr
same problem
