how to check tunnel interface details in ACI cli ?
Hello Experts ,
I am trying to trace the endpoint 10.10.10.18 from source connected leaf switch .From the below output I can see to reach  10.10.10.18 we have to go via tunnel23 ...
How do I check next from cli ? what is the command to check the tunnel 23 ?
GER-DC-LF101# show endpoint ip 10.10.10.18
Legend:
s - arp H - vtep V - vpc-attached p - peer-aged
R - peer-attached-rl B - bounce S - static M - span
D - bounce-to-proxy O - peer-attached a - local-aged m - svc-mgr
L - local E - shared-service
VLAN/ Encap MAC Address MAC Info/ Interface
Domain VLAN IP Address IP Info
SAROVANI:VRF-PROD 10.10.10.18 tunnel23
You can use the following commands:
"show interface tunnel 23" -> to check the destination TEP IP
"acidiag fnvread" to check which leaf has that TEP IP.
Take care,
Sergiu
Hi Expert ,
Can anyone check and share your inputs .
Robert Burns
I'd recommend you check out the Cisco live Session; BRKACI-2641 ACI Troubleshooting Endpoints.  https://www.ciscolive.com/on-demand/on-demand-library.html?search=BRKACI-264#/session/16360600240670017cef
It will answer this and help you when debugging endpoint connectivity issues.
Robert
Hi , I did not find any info regarding tunnel and the commands to check it.
Take care,
Sergiu
