How to downgrade the ACI-Mode OS.
pine78
I am currently using APIC 2.3 (1i), Spine / Leaf 12.3.1i.
I'm trying to add a new leaf switch, but the new leaf switch is version 14.0.
So I will downgrade from version 14.0 to version 12.3.1i and add it to the fabric.
The NX-OS Upgrade / downgrade document exists, but the upgrade / downgrade document for ACI-Mode OS can not be found.
Please tell us how to downgrade the ACI-Mode OS.
Thanks.
stcorry
Hello!
When downgrading an ACI switch manually, you should be able to follow the same directions as when upgrading... When you break into bootloader to specify booting a specific image, you can specify the older image to boot.
stcorry
Hello!
I really appreciate your reply.
