How to manually clear learned L2 endpoint from EPG?
SIMMN
Like screenshot shows, how can I clear out those L2 endpoints manually?
The only way I found so far is to go to the associated BD to toggle the "L2 Unknown Unicast" option but doing that would clear all the learned endpoints...So how about if I just need to clear specific ones?
Sergiu.Daniluk
Hi @SIMMN
I think the command you are looking for is:
Leaf502# vsh
Leaf502# clear system internal epm endpoint key vlan VLAN_ID mac EE:EE:EE:EE:EE:EE
Execute the command directly on the leaf where the EP is learned on.
Stay safe,
Sergiu
