How to resolve high storage usage in /bin directory on Cisco ACI APIC
JohnJudi
Hello everyone,
I am experiencing an issue with high storage usage in the /bin directory on my Cisco ACI APIC.(code F1529)
Unfortunately, I do not have access to Cisco TAC support at the moment.
Has anyone encountered this problem before? What are the best steps or recommended procedures to safely reduce storage usage in this directory without risking system stability?
Any advice or guidance would be greatly appreciated!
Thank you in advance.
Wassim Aouadi
Level 4
Level 4
Hello @JohnJudi ,
Can you post the output of df -h command? There could be a mount that has been filled up and reached its quota.
Forum Tips: 1. Paste images inline - don't attach. 2. If you find my post helpful, please give it a thumbs up or mark it as a correct solution; You never know in the future who you might help doing so..
Thank you for your reply.
Here is the df -h output you requested
This issue is happening on APIC2 and APIC3 in my 3-APIC cluster.
