08-12-2025 02:04 AM
Hello everyone,
I am experiencing an issue with high storage usage in the /bin directory on my Cisco ACI APIC.(code F1529)
Unfortunately, I do not have access to Cisco TAC support at the moment.
Has anyone encountered this problem before? What are the best steps or recommended procedures to safely reduce storage usage in this directory without risking system stability?
Any advice or guidance would be greatly appreciated!
Thank you in advance.
08-12-2025 02:37 AM
Hello @JohnJudi ,
Can you post the output of df -h command? There could be a mount that has been filled up and reached its quota.
08-12-2025 04:53 AM
Thank you for your reply.
Here is the df -h output you requested
This issue is happening on APIC2 and APIC3 in my 3-APIC cluster.
